Up Topic American Welding Society Services / Certifications / welder cert.
- - By intentium Date 08-22-2007 03:24
I work for a John Deere dealer in western KS, there some modification/improvements that have to be added to some of the air seeders. It consists of 27 hours of cleaning off paint and preping the metal and then after the weld, painting. And also 25 hours of welding. It consists of various positions:  vert. fillet, overhead fillet, flat fillet, flat groove, and various thicknesses from 3/16-3/4. Some of our customers want a certified welder to perform these mods, i can weld, but i'm not a welder. What certification would be best for me to satisfy our customers.  Thanks a bunch.
Parent - - By 803056 (*****) Date 08-22-2007 13:19
There are several to chose from. The welder qualification tests are very similar, so I would opt for D1.1.
I assume you are welding carbon steel, so a test on 3/8 inch thick carbon steel plate in the vertical and overhead positons should suffice.
Parent - - By intentium Date 08-22-2007 17:34
yes it is carbon steel, does it make a difference if its flux core
Parent - By 803056 (*****) Date 08-22-2007 18:02
Not from a certification standpoint.
Your certification will only be for the process that you test with.
