Up Topic Welding Industry / General Welding Discussion / im i guess new to welding only 4 yrs
- - By welder freek Date 08-26-2007 15:59
I need help trying to make a better welder out of myself.i need help big time.
Parent - By CWI555 (*****) Date 08-26-2007 16:06
You've came to the right place. However; more specifics are going to be needed. What processes, codes, and materials are you working to?
Parent - - By welder freek Date 08-26-2007 16:09
well i work in a plant ,i use a hobart 6045 welder an 045 wire i run my heat on 26 an wire speed about 7 an my welds are under cut or i have alot of run off
Parent - - By turbolaser (**) Date 08-26-2007 20:14
What thickness and type of material are you welding and in what position(s).  What gas mix are you useing?  I am assuming you are running solid wire.  This info will help us help you.
Parent - - By welder freek Date 08-27-2007 19:54
ok i buld up parts an the thickness is different for different parts.i might have 1part that is 3/8 in thickness and another part might be 1/2in thick.some times i have to weld uphill downhill flat overhead,it just depends on how cought up i am on my regular parts.i dont want to be asked if i can do thes extra jobs an really not know what i am doin.the gas is 25%argon an 75%carbon dioxide solid wire 045 hobart 6045 with wire feeder with a 44lb roll,welder on about 25.5 and wire feeder set on 7.any help i can get will be greatly appreceated.
Parent - - By maverick Date 08-30-2007 19:15
try seting your heat a lil lower....specially if you're overhead. on the speed...what's the range? If you're welding on a thicker surface then you need to slow down a lil. When I run mig I'm using a millermatic 225. My settings are 20(amps) wirespeed is 225 and gas somewhere around 15. I hope this is of some use to you.
Parent - By welder freek Date 08-31-2007 15:53
ty dude i have tryed that an it helped but i just dont think that i can make it in the welding world
Parent - By DaveBoyer (*****) Date 08-27-2007 04:49
You might check out WWW.WeldReality.com This is a great site for MIG welding info. I plan to buy the Manual MIG & Flux Core book soon Myself.
