I use NR 232 in the field. Totally seismic E71T-8 Is E71T-1 rated as a seismic wire ? Is that an AWS rating ? E71T-1 is lincoln's "outershield) Requires a 75/25 cover gas. Spray transfer mode . Is diameter a factor ? .045 or .068 .072 etc ? john los angeles
