Up Topic Welding Industry / General Welding Discussion / flux core wire
- - By EVWELDER (**) Date 08-30-2007 18:06
I like to know your opinions on a good brand of flux core wire for use on thick materials and multi position.
Parent - - By Lawrence (*****) Date 08-30-2007 18:14
Here is a link to a discussion about FCAW wires...... I fell in love with the ESAB, however there are other good ones too
http://aws.org/cgi-bin/mwf/topic_show.pl?pid=61424;hl=esab%20e71t-1#pid61424
Parent - By drifter57 (**) Date 08-30-2007 18:59
Has anybody noticed a difference in your "consumable" usage using ESAB wire? Either to the more or less side??
Parent - By EVWELDER (**) Date 08-30-2007 19:31
I've noticed that people mention dualshield what about fcaw without the gas would the wire still be as good.
Parent - By cwf07 (***) Date 08-30-2007 20:23
Triple 7 by Hobart is a pretty good flux core wire.
Parent - By GRoberts (***) Date 08-31-2007 00:33
There are a lot of good FCAW wires out there, but some things to look for in my opinion:
1. There aren't many FCAW wires classified with an H4 anymore since the latest revision of the diffusible hydrogen testing specification, but use a wire with at least a H8 or lower.  H4 would be better.
2. If you can, use a FCAW wire with a E7XT-12 classification.  This will limit the maximum tensile strength, and result in less residual stress in the base metal (and less cracking potential).
3. Look for a wire with a J on the end for better weld metal toughness and less tendency to crack.
4. If you have very critical applications with high restraint and flat/horizontal only, the best wires to use are E70T-5, but they have a lot of smoke and spatter, so you welders will not like using them.  Going to this step is not usually required though.
Parent - By dschlotz (***) Date 09-01-2007 22:40
Follow the link and see what I replied to another poster.
http://www.aws.org/cgi-bin/mwf/topic_show.pl?tid=12857#fp
Dennis
