Up Topic Welding Industry / General Welding Discussion / differnce between steel
- - By elliott (**) Date 09-13-2007 21:32
how everybody doing. I got a question about some steel. What is the difference beteween a36 and a500 and also do you weld them differently with differnet rod and amps.
Thank again
Parent - - By pipewelder_1999 (****) Date 09-14-2007 02:09
They are both carbon steel. The same as far as welding goes.
Gerald
Parent - - By aevald (*****) Date 09-14-2007 02:16
Hello Gerald, maybe you can clear this up for me. I will often times see the A500 designation on tube steels, yet I have always assumed that they were in fact of an A36 material type, is this an incorrect line of thinking? Thanks and regards, aevald
Parent - - By pipewelder_1999 (****) Date 09-14-2007 10:43
The A500 is for tubing. I am pretty sure they are plain carbon steel. There may be differences in the grades in A500 that I am not aware of but all will be similar as far as welding goes. I don't have a material spec handy so I may be missing something.
Gerald
Parent - By aevald (*****) Date 09-14-2007 13:23
Hello darren, and thank you for the links. From what I read,they appear to be very similar in mechanical and material composition with some slight differences. Much appreciated, have a great day and best regards, Allan
Parent - By aevald (*****) Date 09-14-2007 13:25
Hello Gerald, I believe you are correct as darren included some links in his response that give a listing of the mechanical properties and other characteristics of the two. Best regards, Allan
