Up Topic Welding Industry / General Welding Discussion / Hard Hat Hood
- - By Fitter4life (*) Date 09-16-2007 16:48
I started a new job, and it is required that we wear a hard hat hood. I am quite partial to my Fibre-metal
pipeliner hood. Does anyone have any suggestions for the best set up for attatching the hood to the hard hat? I really appreciate the input.
Parent - - By TANKIE (*) Date 09-16-2007 17:54
FIBRE-METAL MAKES AN ATTATCHEMENT CALLED AA SPEEDY 5000 IT A BAND THAT GOES AROUND YOUR HARD HAT AND HAS TWO TABS THAT LATCH ON TO THE RIM OF YOUR HARD HAT I HAVE USED THEM FOR 10 YRS NOW ITS BETTER THAN THE HARD HAT LUG STYLE YOU CAN PICK ONE OF THESE UP AT ANY WELDING SUPPLY HOPE THIS HELPS, TANKIE
Parent - By scrappywelds (***) Date 09-23-2007 00:47
speedy loop is the best for a pipeliner hood, but alot of the newer pipeliners it will only fit good on a plastic fiber-metal hard hat.
