Hello L. Hall!
I would also like to "Weldcome" you to the forum.
If you could elaborate further as to what specific effects you are alluding to pertaining to OCV, and Slope when a transformer rectifier power source is in it's "static" state...
Now just to clarify a bit, when you mention: "determine the effects of open circuit voltage and slope on the static characteristic of a a transformer rectifier type welding power source." Do you mean when the power source is on yet, not actually welding or as you would possibly refer to: "It's Dynamic characteristics" by the premise that the welding circuit voltage would be closed???
I also wanted to attach a link to ESAB that has a .pdf file on an L-Tec SVI 450 which I know is not the same power source as the SVI 500 you referred to but in the .pdf file, there is some contact information that may or may not steer you towrads the right direction in answering your query. I believe it's worth persuing because, the folks @ what is now known as "ESAB" North America are for the most part, the same folks who worked on the older L-Tec and Linde/Union Carbide welding & cutting power sources.
ESAB NA is located 2 the same area in Florence, SC USA.
So here's the link:
http://www.esabna.com/literature/Arc%20Equipment/Power%20Supplies/15-099-__LTEC_VI450.pdfHere's another manual in .pdf format:
http://www.esabna.com/literature/Arc%20Equipment/Power%20Supplies/15-098-A_VI450.pdfHere is their support page with contact info:
http://www.esabna.com/us/en/support/I hope this info will steer you in the right direction. ;)
