Up Topic Welding Industry / Inspection & Qualification / Question about swps
- - By jws Date 09-17-2007 23:51
Does anyone know if an Aws swps B2.xxxxx is already qualified? I need a wps for 6g pipe but, I do not have the ability to do a tensile specimen.
Parent - By jon20013 (*****) Date 09-18-2007 01:39
SWPS are already qualified, no need to run any additional mechanical tests however a welder must run a coupon using the SWPS... check www.sperkoengineering.com he is the Vice Chair of ASME IX and has an excellent article on precautions to take.  By the way, there's no need to be position specific for a WPS (in most cases) but there is for performance qualification.  Good luck.
