Up Topic Welders and Inspectors / Welding Equipment Classifieds / Steeltailor PortableCNC cutting machine for flame and plasma
- - By laurel Date 09-18-2007 09:28
Portable CNC cutting machine for plasma and oxy-fuel cutting heads Steeltailor
2-Axis CNC Portable Cutting Machine
Looking for Dealers, Distributors
Cut like a big cutting machine with the provided FastCAM software Affordable for all small and medium enterprises Cutting Range: 1200 mm(47")X2000 mm( 78"). Lenght extendable till 6000mm.
Support both plasma cutter and oxy-fuel cutting torch With its USB port, the data transmission from a PC is as easy as
downloading photos from a digital camera. SteelTailor has all the performance of a gantry machine.
An ideal tool for metal work hobbyists, DIY enthusiasts, reparation shops, demolition projects operators, metal scrap yards, street rod chassis builders, machinery works, and others who care about either of the 3 strengths of an oxy-gasoline torch: portability, fuel cost economic, and fuel availability.
Parent - By laurel Date 09-19-2007 09:08
What is SteeltailorP?
SteelTailor P is a portable CNC Cutting Machine.It can cut any complex plane figures as the large-sized gantry CNC cutting machine and support both flame torch and plasma cutter. It is affordable for all enterprises and workshops. The compact design and rational structure make it lightweight,small size and easy to move. It is usable both indoors and outdoors.
By using high quality controllers in its automation system and antimagnetic materials in its housing, SteelTailor P guarantees a reliable and stable CNC operation.
The application of the most up-to-date CNC technology allows independent programming from numerical control . equipment failure and maintenance difficulty are reduced.
The integration of FastCam cutting software makes drawing, nesting and cutting simple and efficient. The software provides high level of material utilization & optimization.
Parent - By laurel Date 09-26-2007 09:23
Http://www.steeltailor.com
