Hello cowgirlsride, is there a specific job that you are trying to qualify for, with a specific company and by chance do you have the details of this such as the WPS ? I am asking because if this is simply to take a specific test you should be able to contact any number of different CWEs and make arrangements for such a test. A few thoughts for consideration. Regards, aevald
Most welding standards that cover aluminum welding require the employer to qualify and certify their welders, i.e., unlike welders qualified and certified to AWS D1.1, the welder's certification is not transportable from one employer to another.
One reason that each employer has to qualify their own welders, or at least they can not utilize the certifications issued by a previous employer, is that in the absence of prequalified welding procedures (as there are with AWS D1.1) each company is required to qualify the aluminum welding procedures they use. The welders should be qualified using the new employer's qualified WPSs.
Even if you qualify when you are tested by a testing laboratory, you will most likely have to be requalified when you are hired to weld aluminum if the company is working to a code or other industry recognized welding standard.
