Yes you can. The alloy you use matters but up to around 50% silver brazing alloy will melt around 1200 F and flow around 1300 F.
You will need a flux for the higher alloys. There different fluxes for different applications.
Seeing as how SS oxidizes very quickly Your work should be very clean, preferably fresh ground, sanded or buffed. We use denatured alcohol most of the time.
