If the chemical composition of the A252 Grade 3 falls within the chemical composition range of a steel that is prequalified in D1.1, it can be used in a prequalified WPS, if approved by the EOR. Any preheat requirements would also be in accordance with the prequalified minimum preheat and interpass temperature. Just a thought.
