Up Topic Welding Industry / Technical Discussions / Welding Stainless Steel with different thermal expansion
- - By jnasr00 Date 10-05-2007 02:05
Hi,
If I weld a stainless steel with a mean coefficient of expansion = 10.6x10^-6 in/F with a filler metal that has a mean coefficient of 8.2x10^-6 in/F does anyone know what effects this has on the weldment? Any references would be much appreciated.
I am very new to welds as you can tell by my question.
cheers
Parent - - By 803056 (*****) Date 10-05-2007 13:20
It would depend on the service environment, the thickness of the joint, etc.
Thermal cycles can lead to low cycle thermal fatigue in some applications.
Parent - By js55 (*****) Date 10-05-2007 14:25
Thats a design question and not likely to find an answer here or in any other forum for that matter.
What's the pressure?
What's the amplitude of the pressure variation in the cycle?
What's the max temp?
What's the min temp?
What's the rapidity with which the temp amplitude changes?
What's the cycling frequency?
What alloys?
What's the service-is it a SCC susceptible?
What's the material thickness?
Are there any thickness transitions?
What about weld quality?
What was the welding thermal cycle-did it prevent segregation?
Etc. etc. etc.
Parent - - By G.S.Crisi (****) Date 10-05-2007 17:39 Edited 10-05-2007 17:44
In my personal opinion, the difference isn't that much to worry about it. In any case, if you're concerned, make a couple of tests.
Prepare two specimens, one with plate and the other with pipe (or both with plate or both with pipe, that's up to you), weld them, allow them to cool and see what happens.
Has the different coefficient of expansion caused any crack, even tiny ones? Be careful.
Are there no cracks? Fine, go ahead and proceed with the welds. The fatigue tests suggested by Al are perfect from a theoretical point of view. From a practical point of view, however, can you afford to make those tests?. They're expensive and, more than that, time consuming.
Parent - By andy (**) Date 10-06-2007 07:33
Although the effects of thermal expansion coefficient of the materials involved is usually related to design conditions and the effects on the weldment in service as mentioned earlier, the only practical problem I see when doing the welding, is the restraint that might be applied across the joint during the heating and cooling cycle of welding. This might lead to cracking as Giovanni has indicated.
If the weld is between two freely moving pieces, then although they both heat up along with the filler, when they cool, because they are unrestrained no detriment should occur in the weld (cracking may still take place due to compositional reasons but this is not what we are concerned with here). If the weld is a closing weld, then the expansion of the parent due to heating may close gaps and on cooling more residual stress might be locked into the joint.  Cracks might now occur if the restraint is sufficiently higher than in the unrestrained weld. Resudial stresses would also be introduced into the weld and parent - these would be present anyway, but the higher the thermal coefficient of expansion the more the magnitude of the residual stresses. Is this correct?
I agree however that in practical terms, the values quoted are more or less similar and no problems should be anticipated.
Parent - - By 803056 (*****) Date 10-07-2007 14:22
I don't mean to be disrespectful, but I must have missed something? I don't recollect suggesting fatigue testing. I only noted that low cycle thermal fatigue can be an issue if the operating conditions or service conditions involve thermal cycling.
A case in point: I have a client that welded carbon steel to 304 stainless steel to fabricate an apron used in the opening of a large heat treating oven. The concern was that the forklifts were continually bumping into the refractory and crushing it. So the carbon steel apron was to provide a barrier against the fork trucks and the stainless steel was to resist the high temperatures of the oven and the occasional bump of a hot piece dropped on to the refractory. They called me in when the new fabrication tore itself apart in the matter of weeks.
The carbon steel and 304 austenitic stainless steel have definite differences in thermal coefficients of expansion. I believe the difference was substantial enough that low cycle thermal fatigue was the culprit. Every time the oven door was opened, a rush of cold air would cool the stainless steel, upon closing the door, it would be reheated to a high temperature. The thermal cycles were repeated several times per shift, three shifts per day. As I said, the apron failed in short order without apparent impact damage from the forklifts. In the absence of physical damage, I assumed the failure was the result of the thermal cycles.
A new apron was designed with some "slip joints" between the hot section and the cold section. It has been in operation for more than a year without signs of failure.
If thermal cycling isn't a consideration, then low cycle thermal fatigue isn't an issue. Austenitic stainless steel typically has sufficient ductility to accommodate considerable differences in expansion and contraction if the only thermal cycle involved is that of making the weld.
Parent - - By G.S.Crisi (****) Date 10-08-2007 20:46
You're right, Al. It was me who misunderstood the meaning of your first post.
English being not my mother language, sometimes I run into a confusion like that.
Parent - By 803056 (*****) Date 10-08-2007 21:43
Not a problem Dr. Crisi.
You should hear how damaging I am to the Spanish language! Now that is a crime according to my old Spanish teacher.
