Up Topic American Welding Society Services / Certifications / 6 year cert
- - By ctacker (****) Date 10-12-2007 23:55 Edited 10-13-2007 07:22
how do you get a 6 year cwi cert? i have seen oct 2013 on at least a couple numbers under CWI quik check!
Edited: 1 number is 07100701 is aug 2013, may have been aug not oct i seen!
Parent - - By Lawrence (*****) Date 10-13-2007 03:02
Don't know about a 6 year cert.
But if you take a second code test you will get another 9 years... So in theory you can go 18 years without a recert/retest if you get take the full test and a second code test in the same year.
I assume AW$  will fix that glitch soon.. So act now.
Parent - By ctacker (****) Date 10-13-2007 05:25
could be another glitch, maybe passed all three parts along with another code part which gave 3 years until vision acuity needs updated for each code!
does that make sense?
