Yorkiepap,
Sorry you are having trouble. Photobucket works well in my experience, but there's a trick you have to do. The IMG code they give you has [IMG] in caps and you have to change it to lower case for our forum. (See
http://www.aws.org/cgi-bin/mwf/forum_help.pl ) Also the [/IMG] at the end of the link has to change to lower case. (I can't write it here in lower case because the server will think I'm putting a picture in.)
The attachment function (not using Photobucket) just puts the pictures at the end, so if you want to position them amidst text descriptions, use Photobucket, make the change in capitalization, and you can put the Photobucket code wherever you want in your post.
Let me know how it goes.
Ross
AWS Marketing
