Dave
. The people who sell these machines do make some distinction on thickness of cut and thickness of shear with thickness of shear being about 40% higher than cut. Miller says that my Spectrum 700 (50A) will cut 5/8" of aluminium but we do routinely cut 1" of aluminium, But the cut is not pretty on this thickness of material. If I was cutting 1" thick all day I would look at a 70A machine. As for air we use plain shop air running through a common water separater, it leave the compressor at 125 psi and we regulate it to 80-90 psi at the plasma unit using the built in regulator. The gases used tend to follow the same lines as those used for gmaw on a similar material. The gas for aluminium is a helium/argon blend (75/25)-(90/10). The higher the percentage of helium the deeper the cut or higher argon for cleaner edge. C steel uses CO2 or more rarely a CO2/argon blend and once again the percentage of argon controls the cleanliness of the edge but limits the cut depth.
As for the machines with a piggy back compressor I have never used one, but I would assume that they work fineand are oriented toward users who want an all-in-one package such as rebar tie'rs.
Oh, and one other thing is that a decent sized plasma can be used to cut all sorts of odd stuff on ocassion such as concrete
I hope this helps you out
......Sean
