What does 100% variation mean?
If the welder varies the amperage from 100 amps to 50 amps, that's a 50% difference.
Travel speed that fluctuate between 8 and 10 ipm, is a 20% variation.
Making a consistent weld size is not to say each weld bead has to be identical when making a groove weld. It is reasonable for the welder to use different travel speed for the root bead and additional weld beads in the case of a multiple pass fillet weld or a groove weld. Consistency in the travel speed of a single pass is not the same as varying the travel speed from one bead to the next.
Likewise, what is the actual welding amperage used for a single pass bead? Anyone who has usedd an ammeter or voltmeter can attest to the fluctuations of both a digital and analog meter while the welder is welding. Do you record the highest value, the lowest value, the "average" value?
What is reasonable? I guess that's were experience comes into to play and statistics helps to separate the meaningful information from the chaff. To expect a manual process to have no variation isn't reasonable to anyone but the academics.
When we conduct PQR testing, I record amps, volts, weld length and time of welding, and preheat/interpass temperature for each pass. I shoot for all passes to remain within the ranges given in the essential variables, using the average of the passes as the baseline.
We run the 5/16" single pass fillet test first (D1.5) , to determine what we will use for the groove test parameters. The difficult part is that welders invarialbly try to run "screamer" passes on the cap to avoid excessive reinforcement - which would be outside the range.
I wish AWS or someone would standardize/define how testing should be done (maybe it exists somewhere but I missed it). I learned what I know through a few years of trial and error in interpreting the code requirements and trying to translate them to what the customer wants. Strangely enough, many different people have many different opinions on right and wrong (go figure!).
But seriously, some folks insist on using the highest and lowest recorded passes for the limits; some are so befuddled by the code that they will "stamp" anything; some want to ignore root and cap passes; some want to include all passes; some insist on seeing data for all passes; some want only the averge reported for the PQR - you name it and there is an advocate for it.
Even on this forum, some very knowledgeable and experienced people are not in full agreement with how testing should be conducted/evaluated. All of the opinions have some merit.
Does anyone know if this has been addressed anywhere? If not, is there anything on the radar?
