Up Topic American Welding Society Services / Certifications / Welder Performance Test With Copper Nickel Filler
- - By tom cooper (**) Date 10-16-2007 17:58
Hi All,
I am in need to qualify a welder with a ERCuNi filler on a tig procedure.  Purpose will be for a ASME B31 copper nickel pipe job coming up.  I would prefer to get this test going right now using a groove weld plate test and RT examination as permitted by QW-304 (we have no pipe for the test right now).
What alternate plate material might be applicable now for this test?
Thanks
Parent - - By js55 (*****) Date 10-16-2007 18:09
You can use carbon steel base metal depending upon the P No. of your Monel.
QW-423.1  P1 to P11, P34, P41 to P49.
And consistent with threads in this forum its up to yuo to decide if this is representative of the skills necessary for your alloy. If its 70-30 its P34.
Parent - By js55 (*****) Date 10-16-2007 18:10
90-10 is P34 also.
Parent - - By pipewelder_1999 (****) Date 10-16-2007 18:59
If you are qualifying for ASME then you may be restricted on your minimum diameter. As others have said, P1 materials are fine for performance qualification.
Parent - - By tom cooper (**) Date 10-16-2007 20:46
Thanks Folks-
The upcoming job will be 70-30. It strikes me so odd that welding ERCuNi on A-36 permits a welder to qualify on Cu-Ni, but since it is permitted in QW-423,  I will take advantage. I certainly understand there is a skill level that may get overlooked when substituting materials on a performance test and would usually opt for the actual production condition when possible,  but in this case we will be qualifying one of our very best so I really have no concerns.
Thank you all you have helped tremendously.
Parent - By js55 (*****) Date 10-16-2007 20:56
I do believe the carbon steel makes the qual a bit easier. But, Monels can be a booger for the uninitiated. The CS won't help much if your welder ain't close to the skill level necessary.
