Up Topic Welding Industry / Technical Discussions / SMAW per ASME IX QW 404.30/QW 353
- - By CWI555 (*****) Date 11-06-2007 00:55
This was a new one to me. Two welders qualified (SMAW) up to 1". Can one of these welders weld the first inch, and then the second welder weld the next inch on a 2" thick weld?
Regards,
Gerald
Parent - - By pipewelder_1999 (****) Date 11-06-2007 00:56
Yes.
Parent - - By 803056 (*****) Date 11-06-2007 03:43
Yes provided the WPS is qualified for the full two inch thickness.
Parent - - By CWI555 (*****) Date 11-06-2007 04:23
learn something new every day. 20 + years in and I can't say I've ever seen the case were it was split between two welders. Usually they are qualified for unlimited.
Parent - - By pipewelder_1999 (****) Date 11-06-2007 11:36
With ASME a 1/2" coupon would qualify for unlimited with most processes provide 3 layers were deposited.
Parent - - By js55 (*****) Date 11-06-2007 14:35
Pipewelder is right on the 1/2" deposit thickness. But this is a somewhat recent revision. If the welder quals are older they may be under the old 3/4" deposit thickness regime.
Parent - By CWI555 (*****) Date 11-06-2007 16:01
Our current situation is under the 3/4" regime
