Single Phase 208-230 or 460. Draws 110-100 or 50 amps, respectively.
Foot pedal, water-cooled torch, flowmeter...the works. It is used.
Output Range 2-400amps ac/dc
It has it all: Spot, Start, Pulse and Crater Fill adjustments.
I plan on ebaying it but am offering it for $3000 here first. A new precision tig in this amperage range will be $5k+ Item is in my garage taking up space.
I tested it out and it welds fine...just played around with it a bit.
Of course, I only have a 60 amp breaker for a welder so i didn't run it flat out or anything.
