Up Topic Welding Industry / Inspection & Qualification / Non-destructive Testing for Friction (Resistance) Welds
- - By Jennifer Date 11-15-2007 15:57
What non-destructive test methods are appropriate for evaluating friction welds?  Where might I find more information?  Thank you.
Parent - - By Lawrence (*****) Date 11-15-2007 16:12 Edited 11-15-2007 16:18
Jennifer
Welcome to the forum
There are quite a few ways to make a friction weld and many more ways to make resistance welds...  You need to provide more information if you want a specific reply.
But here is one thought.
AWS C6.2/C6.2M:2006 SPECIFICATION FOR FRICTION WELDING OF METALS
or
AWS C1.4M/C1.4 SPECIFICATION FOR RESISTANCE WELDING OF CARBON AND LOW-ALLOY STEELS
or
AWS D8.1M:2007, Specification for Automotive Weld Quality and Resistance Spot Welding of Steel,
or
AWS D17.2/ D17.2M:2007, Specification for Resistance Welding for Aerospace Applications
Parent - - By Jennifer Date 11-15-2007 20:58
Thank you for the quick reply! We are friction welding hollow drill mining grade steel (small end spins and is pressed against longer end; the process is new to us (inherited from sister plant), and I'm not familiar with all the methods of friction welding).  We are currently using bend tests to evaluate set-up first-off's - which works for our application - but wish to reduce set-up/test times by employing non-destructive methods.
Parent - By CWI555 (*****) Date 11-15-2007 22:52
I would have to preface my statement in that I can't say as I know what code that would go to if any.
However; I have tested some devices in the nuclear realm (CRDM stalks) in which a similar method was used to put them together.
For them, they used UT, and PT.
Parent - By CWI555 (*****) Date 11-15-2007 16:21
Without knowing specific friction weld information which can allow a more specific answer, Selection of an NDE method(s) will be affected by type of flaw, AQL for the same, and the POD for the method. (acceptable quality level/probability of detection both of which run hand in hand).
regards,
Gerald
