Real-time ultrasonic NDE on hot metal without liquid couplant
Our national R&D laboratory needs your professional opinion.
Is there a technical need for the new ultrasonic technology described below?
Sincerely,
Paul Grahovac, Senior Account Executive
Technology Transfer and Commercialization
Idaho National Engineering and Environmental Laboratory (INEEL)
Bechtel BWXT Idaho, LLC (BBWI)
P. O. Box 1625
2525 North Fremont Avenue
Idaho Falls, ID 83415-3805
Telephone: (208) 526-3488
Fax: (208) 526-0876
E-mail: pg2@inel.gov
Web site: http://www.inel.gov
U.S. Patent No. 6,178,819, January 30, 2001
The present invention relates to an inspection apparatus for evaluating partially completed welds and more particularly, to an inspection apparatus which has an ultrasonic sensor which can be optimally adjusted relative to a partially completed weld such that it may effectively inspect the weld to detect welding flaws and advise an operator of same.
An inspection apparatus for evaluating a partially completed weld is
described and which is utilized in combination with an automated movable welder which moves across a supporting surface, and wherein the inspection apparatus includes a coupling member mounted on the welder; a frame member mounted on the coupling member; an ultrasonic sensor mounted on the frame member and disposed in ultrasonic sound transmitting relation relative to the partially completed weld; and a drive assembly for adjusting the position of the ultrasonic sensor
relative to the partially completed weld.
