Up Topic Welding Industry / Technical Discussions / FYI - DSA BULLETIN 07-03 - UPDATE - AISC RELEASE
- - By pax23 (**) Date 11-16-2007 20:06
I did not see this posted on the site anywhere, I thought I would bring this to the forum member's attention:
DSA's investigation of defective tube steel, or Hollow Section Steel (HSS) as it is also called, continues. DSA Bulletin BU 07-03 has been updated and posted to the DSA Web site, Publications page and Testing Labs page. Pictures of some defective welds found (as well as a good seam weld for comparison purposes) can be found on the Testing Labs page.
http://www.documents.dgs.ca.gov/dsa/bulletins/bu_07-03_update.pdf
Parent - By 803056 (*****) Date 11-16-2007 22:43
Good information to have.
Thanks - Al
Parent - By pax23 (**) Date 12-20-2007 17:54
Parent - By pax23 (**) Date 05-21-2008 20:31
I am a little late on this one:
http://www.documents.dgs.ca.gov/dsa/bulletins/BU_07-03_UPDATE2_3-7-08.pdf
This is DSA's 2nd update to their initial bulletin which came out a couple months ago.
Not sure what to make of this. Seems to be somewhat more extensive than I expected it would be. Looks like buyers need to be more careful on initial inspection and receipt of this material and probably other HSS products. I know of at least one situation where A500 exhibiting the defects mentioned in the DSA bulletin was manufacturing in the good old USA.
Pictures for those interested:
http://www.dsa.dgs.ca.gov/labs/hss_pictures.htm
