Sounds like a feed problem.
Could be clogged/worn liner
Could be worn tips
Could be improper roller tension.
Could be wire feeder old age problems... I have some old D54 duals that did what you describe until they were overhauled.
If something grabs the wire and pinches it... The arc will run right up to the tip.
If the feed slows for any reason, loose rollers, inconsistant speed etc. The arc will run to the tip
Also a poor work lead connection can cause irregular voltage.
Hello Hogan, I believe Lawrence hit on many of the issues that are related to what you are experiencing, just a few others: are you using consumables other than the brand of your guns? A lot of the tips that are out there that are of an aftermarket variety really aren't a bargain as they are made from different alloys or there are other issues with their manufacture that will cause issues such as you are seeing. Are the parameters of this particular welding any different than you have usually used in the past, I ask this based on the duty rating of the guns, if you are operating on the upper end of the amp capacity of a particular gun model you may be overheating the tips and associated parts. Are the feed rolls of the proper type? if the feed rollers are marking the wire in any manner they may be wearing out the contact tip prematurely and causing erratic feeding and an excessive arcing inside of the contact tip and causing the burnback issues. Do you have any alignment issues of the drive rolls or do the bearings and other associated parts of the feeders have any excessive wear issues that would cause alignment issues for the feed rolls? This can cause wire marking as well and lead to erratic feeding. If you are using liners that aren't correctly sized for the .045 wire this can lead to feeding problems, using a 1/16" liner to feed .045 wire isn't necessarily the best choice because of this. Also if you have previously fed a lot of dualshield wire through these liners they can cake up with the dry lubricant that is on the outside of the dualshield wire and cause problems. Possibly consider changing to a new correctly sized liner. Using wire wipers with the hardwire to aid in keeping the liners free of foreign materials that might impede the wire feeding can possibly take care of some of this, you may already be aware, but don't use the wipers on the flux-cored wires. Just a few more thoughts for consideration. Best regards, Allan
