Up Topic American Welding Society Services / Certifications / GMAW mode of transfer
- - By 3m Date 11-21-2007 19:35
Are Spray and Globular different modes of transfer? If they are, then this would be an essential variable for the WPS and the welder can only weld in this mode.
Parent - - By hogan (****) Date 11-21-2007 21:17
yes different, typicaly it would be an essential variable. what code are you working to?
Parent - - By 803056 (*****) Date 11-21-2007 21:41
As hogan asks, what code are you working to? It is an answer that is code dependent.
Parent - - By 3m Date 11-21-2007 23:09
We are testing welders to D1.1. We are also using 95% argon/5% O2 which I think is mainly for Spray.
Parent - By 803056 (*****) Date 11-25-2007 16:41
The mode of transfer is not an essential variable for welder qualification unless you are switching to or from short circuiting transfer. It is an essential variable for the WPS.
Review Table 4.12 if you are using D1.1-2006.
