Up Topic Welding Industry / General Welding Discussion / break in on 300D Lincoln w/Perkins
- - By gillyson Date 11-21-2007 20:32
Got some opinions on breaking in a brand new Lincoln 300D?  Have never owned a new machine, or wanted one, but got a wild hair and bought one. Thought about the new SA200's but was told by some to stay away from the Kabota.   Any opinions are greatfully appreciated (even from Sourdough!!)
Parent - - By darren (***) Date 11-21-2007 21:19
break in is very important according to the miller tech with 30 years experience at being a tech for miller. if you dont want to pay the money, you can do it with a length of grid fencing or an old mattress spring section. just follow the instructions on how much time at each amperage increment and it will work out fine. however when you spend that much on a machine having a professional break it in for a 100 bucks seems worth it.
just my opinion
darren
Parent - - By 52lincoln (***) Date 11-21-2007 22:52
what do u do with the spring?
Parent - - By DaveBoyer (*****) Date 11-22-2007 03:36
My guess is that You use the spring as a load bank.
Parent - By darren (***) Date 11-22-2007 10:48
yup
Parent - By SPARKYCA (**) Date 11-22-2007 02:10
I would definately put some good  load on her in the first few hours. I have a yr 2000  model that burns 1 1/2 to 2 liters oil every 200 hrs, may be because I did'nt work it hard enough, although I didn't let it idle much during the first 50-60 hrs. Running at a constant rpm does'nt help with seating the rings I've heard.  The machine just turned over 4900 hrs on the hr meter. Only things ( other than regular maint. ) I've done is change the water pump and a voltage sensor on the 110 volt circuit. It has saved me a bundle on fuel.  Have a good day - WS
