You say that the controls will be used in petrochemical and chemical industries and corrosion isn't a concern.
A word of warning: if the medium whose level they will control is strongly caustic, i.e., pH above 9, and it will come in contact with the weld (you say it won't but one never knows), then corrosion IS a concern, because the backing ring will promote caustic embrittlement.
By the way, from the description you've made, I'd think that the devices are Leveltrols, which used to be made by Fisher. Am I right?
