From memory I'll suggest looking into the product data sheets from the manufacturer of the pickling products you use. Either the MSDS or the product information sheet should specify how to store the material.
The last pickling product we used was supplied in a plastic container. Unless you are using some very aggressive acids, you should be able to store them relatively simply.
Sorry I can't be of better help. Maybe if you post the product identification, someone will offer better advice.
Charles
You can use safely high density polyethylene (HDPE), polypropylene, rubber lined or epoxy lined carbon steel.
I prefer them over PVC. Teflon is fine but very expensive.
DON'T use FRP (fiberglass reinforced polyester), it doesn't withstand hydrofluoric acid.
