I did not say there was no disconnect, There is one, We have ran our home on this generator for several days when we had the ice storm here in Indiana, Never once had any problems till I got it back from the dud that repaired it, Any way the rest of the story, The X is not a color, It is a O with a X inside the O, The jumper goes from the green to the X connect, There for I get 220 volts to our home, Then it splits to 2 110 Volts @ side, And 220 to Dryer, AC, Water Well Pump, Water Heater, I never had to use a transformer, 9000 watt surge was not enough to pull the AC, etc in our home, I have ran every thing in our home on a China made 3500 Watt Gen w/ 220 3 wire, Believe it or not it ran every thing, Except the AC, With ever thing powerd up, Hardly pulled the lil guy down, Matter of fact I sold them after the ice storm 70 to be exact, Buyers did not think they would run it, Till I showed them, This sold them, I should have kept a spare for a back up,
Now back to my gen problem, I called my friend a electrical contractor I had a lose wire to the disconnect, Now everthing is operating just fine,
I am not a genius but I do know better then to run power w/ out a disconnect, And if you do not agree this 220 volts will not run our home with no problems you better do some more research , Thanks For Your Input..
Robert is tetnically corect about the 3 wire, HOWEVER the 4 wire plug is a relatively recent development. The neutral and ground wire are allowed to be connected at the source. The green wire should allso be connected to a copper clad ground rod driven into the earth. Older equipment [and Your China generator] uses the same prong on the plug for ground and neutral. Which wire is which in Your situation is for You to determine with a volt meter. There will be 220 volts across the 2 hot leads, and 110 from either hot lead to neutral or to ground if the ground is tied to the neutral. Modern electric services in many places DO NOT connect the ground and neutral buss bars in the box, but run a cable [usually #4] from EACH ONE to its own driven ground rod. If You have a poor connection on the neutral wire, when load is put on one 110 circut, the voltage on that side will go down, BUT THE VOLTAGE ON THE OTHER 110 CIRCUT WILL GO UP.
