I have been told that i can weld chrome-moly tubing .083 1", using the mig process. I am building kart frames. I was told that i could use ER70S-2 wire, but ER80S-D2 would be a better choice to use for strength. I will be preheating the tubing prior to tacking and welding. Some of my concern are this, I will be welding mild steel tabs for seat bracket and throttle linkage to the 4030 tubing . I was told to use 75/25 )AR/CO2). Would there be any problem using this wire and shielding gas. By the way I want to use .030 wire. I did find it in the ER80-D2, but not in the ER 70-2 wire. Any help would be very appreciated. Thanks in advance for your comments and suggestions.
