Up Topic Welding Industry / General Welding Discussion / Ford F250 too small for Lincoln SA-200?
- - By edfritsch (*) Date 12-03-2007 21:44
Is a Lincoln SA-200 Pipeliner too heavy for a Ford F250?
Parent - By KSellon (****) Date 12-03-2007 22:17
The machine is approx 1300#. Once you get tooled up that will be your problem. Most of this guys run 12,000 fully loaded.
Parent - By texasrigwelder (**) Date 12-04-2007 01:15
no get some air bags and load her down, a 200 its self wont hurt you a bit
Parent - - By JescoPressure (**) Date 12-04-2007 01:27
lots of guys runnin 3/4 ton rigs. Air bags or add a leaf in the back are good enough
Parent - By rig welder6 (**) Date 12-06-2007 04:29
don't get caught by the DOT
