Noel,
If the contractors first PQR (10 mm) is not 13 mm thick minimum as per QW200.4 (b) then it cannot be combined with a second PQR of greater thickness to give coverage from 5 - 200 mm.
(b) For GTAW, SMAW, GMAW, PAW, and SAW,
or combinations of these processes, a PQR for a process
recording a test coupon that was at least 1⁄2 in. (13 mm)
thick may be combined with one or more other PQRs
recording another welding process and any greater base
metal thickness. In this case, the process recorded on
the first PQR may be used to deposit the root layers
using the process(es) recorded on that PQR up to 2t
(for short-circuiting type of GMAW, see QW-404.32)
in thickness on base metal of the maximum thickness
qualified by the other PQR(s) used to support the WPS.
The requirements of Note (1) of QW-451.1 and QW-
451.2 shall apply.
Hope that helps,
Regards,
Shane
