My suggestion would be to ditch the backing strips.
3/8 with short circuit and a backing strip is poor engineering anyhow... It can be done, but it can be done better with spray transfer flat and horizontal or FCAW in all positions
Without a backing strip you can go open root with your typical included angles for the bevel, a 1/8 inch root opening in 1G,2G and 4G and a 3/32 root opening for 3G... Make your root faces a consistant 1/16th....
If your working to D1.1 it will qualify for both open root and with backing. If your short circuiting you will need to qualify the procedure anyhow, so you might as well make it go a little further.
Thats my 02 cents
