Up Topic Welding Industry / Technical Discussions / Welding 3003 Aluminum autogenously
- - By KevinA Date 12-19-2007 15:27
Hi All,
New to the forum. Thanks for any help.
I am looking at laser welding 3003 aluminum tubing for refrigeration systems. The tubes would be placed side-by-side and a laser weld made at the point of contact along the resulting seam. ( cross section looks like: OO  )
I cannot find any details if this can be done autogenously. Any thoughts?
Thanks,
Kevin
Parent - By aevald (*****) Date 12-20-2007 04:38
Hello Kevin, I am not a laser tech by any means, however I would have to say that you might end up with wall thickness reduction issues if you try to autogenously weld the two tubes together without some sort of filler. If I'm wrong on this, I am certainly here to learn along with everyone else. Best regards, aevald
