If your company is legitimate, OSHA already knows about you and you will be inspected at some point. The only way around that is if they either don't know you're there or they don't know what you do there.
I recommend a visit to this website for a little bit of info:
http://www.osha.gov/Also, here are the OSHA elements of the Code of Federal Regulations:
http://www.osha.gov/pls/oshaweb/owastand.display_standard_group?p_toc_level=1&p_part_number=1910As previously stated, if your employer looks at safety as you indicate, it might be better to cut and run. But if you're trying to make a difference in a dangerous place, there are thousands of resources to help you out. Good luck.
