Up Topic Welding Industry / General Welding Discussion / 1967 SA 200 wiring diagram/info
- - By Keplinger78 (**) Date 12-26-2007 02:53
Hello All,
I'm wanting to rewire my 67 redface to front controls,and add oil,water and volt gauges to the front panel.
#1 is this machine positive ground?  positve to frame,neg to starter?
It's now neg ground,when the mag is switched off it grounds with the switch to kill the motor.
Is this correct?
#2 can someone provide the info needed to rewire the charging system? I'm not sure it even works....
I know the ampmeter is not working but I was going to remove it anyway.
If not is there brackets to install a chevy alt????
Thanks Tom K.
Parent - By 52lincoln (***) Date 12-26-2007 04:54
some where wired positive ground,but i think they were older than that.
Parent - By am0resperr0s1 (*) Date 12-26-2007 07:33 Edited 12-26-2007 07:36
Try this link right here http://www.mylincolnelectric.com/Catalog/lecotextsearch.aspx Enter your Machine's code in the product number box! You will get some wiring info about your machine there! Hope it helps in some way! Tony
Parent - By KSellon (****) Date 12-26-2007 16:48
You will have to build your own alternator bracket. Easiest to run with a one-wire delco alt.
