Up Topic Welding Industry / Technical Discussions / WPS
- - By Du Xuan Binh Date 12-29-2007 02:36
Dear All,
if I qualify a WPS for A333 Gr6 at charpy -46c that should also qualify for API 5L X60.
Code/ Standards: ASME IX and ASME B31.3
Regards,
Du Xuan Binh
Parent - - By jon20013 (*****) Date 12-29-2007 03:27
A333, Gr 6 is P1, Gr. 1, and API 5L X60 is P1, Gr. 2.
Since you mention CVN's the answer is "no" A333, Gr. 6 does not qualify API 5L, X60, see QW-403.5; supplementary essential variable.
Parent - - By toddler (**) Date 12-29-2007 12:17
Jon,
How about if API 5L X60 (and say SA-53/106) do not require impact test, can it be supported by a PQR with impact test such as above?
Parent - - By jon20013 (*****) Date 12-29-2007 14:22
In my opinion, the answer is yes.
In my previous shop, I used to qualify all our WPS' with impacts (well, only those materials where many codes typically require impacts), and then used them freely on materials which did not require impacts.  This way I had all my bases covered.
I had to explain this to an auditor once or twice because he was trying to apply my impact notations while I was using the WPS for non-impact work.  It would probably be "cleaner" for me to have simply developed a second WPS but that's an after-thought.
Parent - By toddler (**) Date 12-30-2007 03:18
Thanks jon. I am of the same opinion. Now I'm quite confident I am doing it right. I'll be on a trip to visit one of our "problematic" project. Regards!
Parent - By Du Xuan Binh Date 12-30-2007 04:44
Dear Sir,
Thanks for your support.
A333 Gr6: P-No.1 Group No.1
API 5L X60 : S-No. 1 Group No.2
Parent - - By QUOCVUONG (*) Date 01-07-2008 03:11
[deleted]
Parent - By ctacker (****) Date 01-07-2008 20:23
huh?
Parent - By Bob Garner (***) Date 01-07-2008 23:25
Choy duc hoi!
