Up Topic Welding Industry / General Welding Discussion / PROPANE TANK
- - By Milton Gravitt (***) Date 01-01-2008 17:25 Edited 01-01-2008 17:28
I have question about propane tanks for BBQ grills. When turning the tank on do you turn the valve all the way on are a 1/4 turn like you would on a acetylene cylinder.
Parent - - By rlitman (***) Date 01-01-2008 18:14
You only need to turn the valve all the way on high pressure cylinders (basically cylinders containing only pressurized gas, but not gas over liquid), because those are the ones with double seated valves (like oxygen, argon, nitrogen, helium, etc.).
So, propane tanks only need to be opened a half turn or so.
Parent - By Milton Gravitt (***) Date 01-01-2008 19:36
Thanks for your reply rlitman.
