If your welding alloy 600 on a nuclear reactor your probably doing a repair on cracking. Therefore I strongly advise you to seek proper engineering advice. If you are the engineer, I suggest you contact Areva nuclear services, GE nuclear services, or Westinghouse nuclear services for their expertise as they all have specific information in this regards since the cracking issue first surfaced on alloy 600 a few years back. I've contracted to all three of them and can safely say, the "repair", must be taken on an individual case basis, and not in general terms. There is no "cheap" option for what you are dealing with, even if it's a new weld, which I very seriously doubt, that knowledge is going to be necessary to prevent issues in the future.
Regards,
Gerald
Vscid,
It realy does not matter if it's a Nuclear Reactor or a pipeline or a process plant you need to look at the WPS and follow it. Now if someone is pushing you to weld to fast and your concerned that you are violating that temp. than all the more reason to lean on that WPS. It's takes away all opinion and debate especially in the Nuclear enviroment. If you have looked at the WPS and your just concerned that you think it is wrong than bring it up to the field engineering staff. Have you seen the WPS for the work your doing? It's obvious that you have seen an MTR of some kind, so you do have access to relevant information. Is this a fab shop that works on Nuclear components? or are you working at a Nuclear facility?
Thanks
Jim Hughes
