Up Topic Welding Industry / Technical Discussions / filler for 201LN
- - By sathyasaravanan Date 01-03-2008 11:03
Dear all,
          I am required to weld 201LN using butt joint the U.T.S for the material is 655 Mpa min,yield strength is 310 MPa  min and elongation is 45%min.I want somebody to suggest ,which filler wire  and process I have to use.
Parent - - By waynekoe (**) Date 01-05-2008 00:18
Contact Allegheny Ludlum at www.alleghenyludlum.com, they can set you in the right direction pertaining to any technical how tos' and what ifs'. Hope this helps. Wayne
Parent - - By sathyasaravanan Date 01-06-2008 04:15
thank you
Parent - By IHnum1 Date 05-02-2008 17:57
What is your application for the 201LN?  What type of welding process do you want to use?
