By noswal
Date 02-12-2002 16:40
Depending on what the "Destructive Tests" specs call for to determine nugget diameter, one could resort to the good ol' peel test which is prying or pulling welded assemblies apart. Using a plasma cutter or band saw, cut your work piece into "coupons" and tear away using "large nippers". A weld button is always slightly larger than the weld nugget.
