Up Topic Welding Industry / General Welding Discussion / 1947 Lincoln sa200
- - By wolfhunter1256 Date 01-11-2008 03:22
I just bought this welder from a old operator that used it to weld on a backhoe . I got the ser. # of and it is A192777 code 974. Guy said that it makes power on the 110 outlet but wouldn't weld and never investigated it ! hasn't ran in 8 years but isn't bad shape at all motor turns and is complete ,said he always stared with some batteries in series and it has no crank with it . Were should I start or is it worth starting on? Oh ya the dials are stuck in place from rust .
Parent - By JescoPressure (**) Date 01-11-2008 04:01
sounds like a nice project. I always wanted a stubbie . If you dont want it im sure someone on here will give you an offer
Parent - By raftergwelding (*****) Date 01-11-2008 12:06
hmmm does it have a starter,fly wheel,alernator? if not you need those + flywheel, push button switch and a couple toggle switches let me know i have it all and yes its for sale
