so even on small lines you guys have to test down there before going? Up here you pull up on job ( kickoff) and no matter what you are doing (cap, hotpass, beads) you weld out (bead,hot,cap) the first joint in series (beadhand, then hotpass, then cappers) then the xray pulls up shoots then you are good to go. This isnt on every job , smaller (3 kms) of 3" or 4" or 6" . Bigger jobs (300 klicks of 24 or 36 you usually test before the job. Now i can only speak for up in canada so not arguing about what goes down in the states but i logged alot of clicks mainlining in AB. with my 305g and never a problem, i do agree i would feel alittle weird pulling up on a big spread doing 200 clicks of 36" with it but these machines have no problem stayin up with SA 200's . look at the picture of this beadhand and his resume and look at the machine in the back his truck
http://www.owsc.ca/pwscInstructors.html Like i said im not argueing your point on what will fly in the states when you show up to test. But maybe inspectors should start looking at these machines differently. I also say they arent the best machine but they definately work
