Up Topic Welding Industry / General Welding Discussion / new miller 350d w/diesel
- - By rig welder6 (**) Date 01-15-2008 03:42
anybody heard good or bad about them?
Parent - - By Justin O (**) Date 01-15-2008 12:56
does it have the cat diesel
Parent - - By rig welder6 (**) Date 01-16-2008 02:37
26 hs kubota, i have heard good things about the motor in other applications, i wish it had the perkins
Parent - - By 1mancrew (**) Date 01-16-2008 22:10
the only bad thing I've heard about Kubota engines is the noise. I have a buddy with a 3 cyl. Kubota in a trailblazer and I'll swear to you; this thing could wake the dead!! Flip side of the coin is he got 7000hrs with no trouble and to be frank, if noise bothers you, you're in the wrong line of work. I have the pro 300 with the 3 cyl. cat and I have had great luck with it.
Hope this helps.
GH Weidman
Parent - - By banshee35 (**) Date 01-17-2008 02:28
HeHe, I like exhaust noise. What kind of noise are you describing? SA-200 noise? or 300d noise?
Parent - By rig welder6 (**) Date 01-17-2008 04:24 Edited 01-17-2008 04:34
thanks for the info guys, i'm looking into if i could get a cat instead of kubota, but hey if your making lots of noise it sounds like your doing lots of work. hehehehehe
Oh ya i think they make things called ear plugs too. HUH!
