Up Topic Welding Industry / Technical Discussions / requirement of impact
- - By sathyasaravanan Date 01-21-2008 08:15
One of my Inspector claims that impact is a requirement for P-23 materials as per sec IX ,but I am no able to find it.Does any body know in which part of the code SEC IX it is mentioned.
Parent - - By jon20013 (*****) Date 01-21-2008 10:16
Section IX doesnt require impacts, only the constructing codes specify when impacts are required.
Parent - - By js55 (*****) Date 01-21-2008 14:55
Inform your inspector that you wish to do everything necessary to comply with his expertise, and then ask him to kindly show you where Section IX says that. Enjoy.
Parent - - By jon20013 (*****) Date 01-21-2008 17:49
;-)  Great answer!
Parent - - By js55 (*****) Date 01-21-2008 18:40
It works too. As long as you don't have any inspection hold points cause that boys gonna be turnin pages til the last snowfall in Kazahkstan.
Parent - - By 803056 (*****) Date 01-21-2008 21:51
By P-23, I assume he's talking about an aluminum alloy, right?
Parent - - By js55 (*****) Date 01-21-2008 22:43
I was thinkin Al to Al.  Not being redundant. :>)
In which case notched tensiles might be a better test.
Though it could be the W/V/Nb 2 1/4 Cr stuff too. Though the hyphen indicates Al, Al.
Parent - - By 803056 (*****) Date 01-22-2008 12:57
Impact testing doesn't usually apply to aluminum in my experience. Aluminum's mechanical properties actually improve at lower temperatures until you get really low.
Parent - - By js55 (*****) Date 01-22-2008 14:57
Me too Al. Recognizing that the Al family of alloys is expanding all the time, though not so much in the P-23 group, to my knowledge, the new stuff tending towards much higher strength alloys, Al, as a austenitic microstruture will generally not have the ductile to brittle transition typical of impact testing regime alloys.
Parent - By jon20013 (*****) Date 01-22-2008 16:01
huh.  maybe a newby Inspector?
Parent - By CWI555 (*****) Date 01-23-2008 03:17
No not usually. Until you get into cryogenic ranges, then it gets confugaled.
Parent - - By CWI555 (*****) Date 01-23-2008 03:18
Whats your construction code?
Parent - By sathyasaravanan Date 01-23-2008 05:37
Application is cryogenic and  code is IS standard. thanks and regards.
