dwight , thats a tough question . i have given them away in the past not needing them anymore . if you need to establish value the spindles probably cost $50+ each , tires and rims say $50 each , hitch $50+ so add up = $250 . the real value would probably be the lincoln hub caps if you have them probably worth $40+ each . so all that said you may want to ask him what he's willing to pay some times someone that wants or has a need may see it differently . Good luck . willie
