There have to be a lot of questions answered, before an answer can be given.: Volts, amps, wire, Process, gas Etc. John
The AWS publishes
Certified Welding Supervisor Manual For Quality and Productivity Improvement
Total Welding Management by J.R Barckhoff is also a good read for folks with questions like yours.
These volumes look systemically at production... Weld volume, Arc time per weldment, Reject/Scrap reduction, Reduced work effort, and reduced motion and Delay times....
I like the systemic approach as opposed to putting out fires as they break out. It requires a big time investment in process control but you will find that it can save millions if you are producing at any kind of volume.
