Up Topic American Welding Society Services / Certifications / La certified
- - By Magnetic-re Date 01-25-2008 23:29
need help!! where exactley do I go to get this L.A. cert what building? what address?? I just need to take the written part cause i've already got the physical hands on cert... It expires in 6 month if it is not in use? What if i'm self employed how do I show that ive been welding with the process?? need help thanks for your time
Parent - - By dsolid Date 01-26-2008 03:41
You could try their call center at http://www.ladbs.org/about_us/ccc.htm they should be able to direct you to whoever you need.
Parent - By Magnetic-re Date 01-26-2008 05:21
thanks alot. really appriciate your help
