Up Topic Welding Industry / General Welding Discussion / Welder armature's
- - By JIMMY_B (*) Date 01-28-2008 16:04
Does anyone know what exact year Lincoln came out with the hex shape armature's on the sa 200? And why they went from round to the hex shape.
Parent - - By 52lincoln (***) Date 01-29-2008 01:06
i think it was 1970
Parent - - By JIMMY_B (*) Date 01-30-2008 02:00
Thanks for the reply. I was kinda thinking the same. Someone told me they had a black face with a round armature and I tought all black face machine's had the hex shape. I told him maybe someone just changed the face plate because I have seen a bunch of black face plates on red face machine's I think when lincoln stop making face plate's the red ones sold out quick so they just started using the black one's they both share the same part numbers but now you can find a red one but not a black one. Thanks again.
Parent - - By raftergwelding (*****) Date 01-30-2008 02:19
there were black face machines in the early 70's with slick armitures just like the red fraces
Parent - - By RioCampo (***) Date 01-30-2008 02:27
72 or 73 not sure which. Early 70's models had blackface with round armature.
Parent - - By 52lincoln (***) Date 01-30-2008 02:53
i had a 73 that wasnt must be 72
Parent - By PlanB (*) Date 01-30-2008 03:35
I had a couple 71s in the shop at the same time, both black faces, one round barrel, one hex. both were original. Lincoln tech told me they did not know, they thought the last round gen was code 7044. Have another black face 71 here now, round gen, all original, bought from the original owner. They all weld good.
Parent - By JIMMY_B (*) Date 01-30-2008 03:43
Thanks for the info. I have one more question when did they stop using generators and started with alternators on the charging system? I have seen some black face's with what looks like a factory alternator with the regulator on the cross member frame. I know that my 66 sa 200 has a gen. with the reg. mounted on it and not the frame. Just wondering thats all. Thanks
