Up Topic Welding Industry / Technical Discussions / Tack Certifications For T,K,Y connections
- - By NormanE Date 01-29-2008 19:16
What section in D1.1 or D1.5 covers tack weld certifications/qualifications for T,K,Y connections.
Norman E.
Parent - - By swnorris (****) Date 01-30-2008 17:30
Norman,
In D1.1, see 4.19.2, and then 4.19.2.1 for the extent of the qualification.
Parent - - By NormanE Date 01-30-2008 22:30
I have read those sections, which is why I posted the question. What is the tack welding certification requirements that cover T,K,Y connections. Or am I missing something here.
Parent - - By swnorris (****) Date 01-30-2008 22:46
Norman,
I think you missed the last sentence which basically indicates that only welders fully qualified to weld T-K-Y connections can tack weld T-K-Y connections in the process and position in which the welding is to be done.
Parent - - By NormanE Date 02-01-2008 15:57
Thanks. Your right...I read it again. So let it be written....So let it be done!
Parent - - By 803056 (*****) Date 02-01-2008 20:33
I don't believe D1.5 addresses tubular structures.
Parent - By James Corbin (**) Date 02-09-2008 00:36
Al, you are correct the D1.5 Defaults all tubular to D1.1 even if it is used on a bridge. (Section 10 Tubular Structures "No Applications Within This Code")
Parent - By weldgault (**) Date 02-08-2008 22:27
Not sure, but I think a 6GR qualification, will cover this.  John
